anyone made any new menu`s that will display 4 movie`s yet ?
Yes. I burned a dvd with a serial that had 15 episodes and each episode is selectable from the menu. Does this qualify for your question?
hello guest,
My first menu took me 3 hours to make. After burning over 40 dvdr and each one having a different menu, it now takes about 3 minutes to whip out a menu, therefore I don't use templates. I use DVD Maestro for all the authoring and nero for burning. I have had total success with the + system. I have reviewed the problems in this forum and it seems that most of the problems are with the individual and not the + system. If everyone will follow the guidelines set forth by ChrissyBoy/aka/Badger they will have success also. The more you do the easier it gets.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
